225 amp mega fuse.
225 amp mega fuse.
Post by 626 » Monday, 08 November 2010, 19:56 PM
Just a quick pic of my mega fuse and holder. The wire is 1 gauge. The fuse is 225 amps. It sits on a bracket I fabricated. It protects the wire run where it passes through the firewall.
Each piece of equipment is also fused individually.
DixieEcho82
Radio: RCI, Galaxy, Uniden
Home Phone: 910-648-6281
Re: 225 amp mega fuse.
Post by DixieEcho82 » Wednesday, 17 November 2010, 17:12 PM
Very nice. Just curious, what model of vehicle is that?
yankee
Mud-Duck Sr.
Mud-Duck Sr.
Post by yankee » Wednesday, 17 November 2010, 17:22 PM
Looks lik a jeep. Maybe an older cj
Post by 626 » Wednesday, 17 November 2010, 17:30 PM
That is a 1991 Jeep Wrangler
Those fuse holders are really very cool. They function as a junction block as well, you can connect several pieces of equipment. I use it because I have a cable running through the firewall and anytime you have a junction like that its a good idea to protect it with a fuse. Keep in mind that the fuse protects the jeep from burning down. Not the equipment
For the record, its an older YJ and the body is really similar to a CJ7
rv_camper
Post by rv_camper » Tuesday, 21 January 2014, 13:35 PM
I like the fuse setup, but I'm a little concerned about the current carrying capacity of the wire.
According to my charts, the 225 amp fuse you have is oversized for the 1 gauge wire. Is it possible you're actually using 1/0 cable?
You're not going to be drawing a continuous 225 amps, so I really don't see an overload condition heating the wire significantly, but you may be getting unnecessary voltage drop across the wire depending on the length.
Post by 'Doc » Monday, 03 February 2014, 17:53 PM
If it were me, I think I'd use a slightly smaller fuse/breaker than 225 amps. The size of cable isn't an issue, it's as large as the starter cable so I would think it ought'a handle anything you are likely to have as an electrical accessory. I don't think you need to run out and change the size of that fuse! ...unless you are going to give it to me, naturally...
