motormaul setup
natureboy
Mud-Duck Sr.
Mud-Duck Sr.
Home Phone: 6622973245
motormaul setup
Post by natureboy » Sunday, 29 August 2010, 19:24 PM
How does a *Censored* work and does is charge off of your 12v system if not how long does it stay charged until needing to charge it
linx
Radio: 2 tin cans + string
Referrals: 6
Re: motormaul setup
Post by linx » Monday, 30 August 2010, 9:05 AM
Yes a motor *Censored* does charge off your 12v system.
In short, a heavy gauge wire goes from your stock system to the motor *Censored*. The motor *Censored* then goes to a bank of batteries. The advantage to a *Censored* is you can increase the voltage with a voltage regulator. The disadvantage is price and its dangerous having batteries in the cab with you b/c of noxious gases that batteries (even sealed batteries) can release. You're looking at probably $1500 for a *Censored* setup.
I can't post it from my blackberry, but there's some youtube vids on *Censored*.
One word of "caution" or "wisdom" is as I said in your other post. Going from 800w swing to 1500w swing is going to be little to no difference on the receiving end. In order to create 1 s-unit of receive you would have to triple the output. So to go from 6 lbs to 7 lbs to a far off station would mean the difference of 800w to 2400w. If you can't get to that number it wouldn't do a ton of good unless your just trying to key over the driver next to you who's running 1000w and your doing the 800 and want to be doing 1500. That's a lot of cash to throw at a pissing match. Trust me, I've been there haha.
Admin - CBRT Complaints Department
Support our fine sponsors!
VOTE FOR CBRT TODAY!
CBRT ON TWITTER!!!
My Twitter Too
drdx
Re: motormaul setup
Post by drdx » Monday, 30 August 2010, 12:25 PM
Lynx summed it up. Then, once you're all tuned up and doing that 2400, you drive into an RF hole, killing your signal, and it is like you're barefoot. That's radio. Location is the deal once you're up to having a decent signal. While there is no replacement for raw ERP (effective radiated power) it does take a bunch to move that needle up, especially once you're in the kw+ range. One phrase comes to mind: Diminishing return.
natureboy
Mud-Duck Sr.
Mud-Duck Sr.
Re: motormaul setup
Post by natureboy » Monday, 30 August 2010, 16:35 PM
Thanks guys
Natureboy in indianola, miss
