16 or 32 possible ?
p71vic
16 or 32 possible ?
#235403
Post by p71vic »
I have a old crown vic with a 250 amp alternator.
Various radios running a 667 tx star.
I want to install a maul and push a 16 or maybe a 32.
Realistic expectation ?
North Texas Mudduck
Re: 16 or 32 possible ?
#235410
Post by North Texas Mudduck »
16 pill for sure
with a puck mount on the trunck
linearone
#235712
Post by linearone »
a 16 for sure with a 400 amp maul for safety. a 32 only if you buy a big expensive maul like the one fatboy has but doesnt advertise... whoops did I jsut slip something out?
Its CB radio, plug and play technology, its just not that hard folks...
North Texas Mudduck
#235743
linearone wrote:a 16 for sure with a 400 amp maul for safety. a 32 only if you buy a big expensive maul like the one fatboy has but doesnt advertise... whoops did I jsut slip something out?
and its a Big Maul
if i remember right it takes up to 8 or 10 batteries
MECHMAN
Sponsor
Sponsor
Real Name: Matthew
#236057
Post by MECHMAN »
p71vic wrote:I have a old crown vic with a 250 amp alternator.
depending on the year, I have dual alternator brackets for a crown vic. You could just run two 250's in parralel with a couple decent batteries and you wouldn't need a maul. (and you wouldn't have to recharge the batteries)
Call us for all your high output alternator and battery needs !!
[/u][/size]
1 - 888 - MECHMAN
the_junkie
#236100
Post by the_junkie »
there is no need to recharge the batteries...that's what the motor maul is for. It charges the batteries constantly, then when the amplifier is keyed up, it switches the solenoids over to seperate the maul from the al, and moves the 12v batts to series, making a 24v stack, then lowers the voltage down to go out to your amplifier...
127
#236111
Post by 127 »
The 800 amp motor maul requires 8 batteries and if you don't mind completely losing the trunk plus some back seat area then go for it. 500 lbs of batteries in the trunk definately be a safety hazard.
A 16 or 32 pill is not a toy like a Texas Star and if you don't know exactly what you are doing then learn first or it'll become a money pit.
Worldwide has one and it'll feed a 32 pill.
http://www.worldwideamplifier ... rmaul.html
PYRO-736
Real Name: Jimmy
Radio: Connex 3300
#242283
Post by PYRO-736 »
I need to ask-not to be a d#$K but just to know--everyone is set on motormauls. You get a big 800 amp maul then 8 to 10 batteries- no trunk left, no money left cause the price of the BIG mauls are ludicrous, then the price of all those batteries added to the mauls price- why dont you especially on an older vehicle with lots of engine compartment left just add a second charging system? will cost around the same as the maul once everything is done and youll have a lot more capabilities in my eyes. I know mauls work great but if you got the room to play why not use it for a couple of alternators?
