Motor Maul
The Bull
Motor Maul
Post by The Bull » Tuesday, 10 February 2009, 18:38 PM
Dose anyone know if there are plans out there to build your own motor *Censored*? is it even posible?
drdx
Post by drdx » Tuesday, 10 February 2009, 19:06 PM
I'm sure it is possible to construct one. After all, they do. Basically, it is a brain that has a relay and a regulator circuit, and that relay is RF triggered to disconnect it from the vehicle when transmitting. The regulator part allows "volting". Am I remotely close here? I'm just guessing and curious. Great question.
Yes it's me, Dollar-98, drdx, the original all *Censored*, shot cawla on workin this no-fade technology.
The Bull
Post by The Bull » Tuesday, 10 February 2009, 20:00 PM
ya drdx i konw its a good question, im lookin to build my own
The Bull
Post by The Bull » Saturday, 14 February 2009, 22:34 PM
dose anyone have pics of the inside of a motor *Censored*?
Thunder1337
Post by Thunder1337 » Saturday, 14 February 2009, 22:52 PM
Here's a good vid of one being used thats all I could find so far.
The Bull
Re: Motor Maul
Post by The Bull » Sunday, 15 February 2009, 18:13 PM
ya thunder thats all i can find, these things must be a deep secrect
Darkskies
Radio: Galaxy DX55
Home Phone: 8509510475
Re: Motor Maul
Post by Darkskies » Saturday, 04 April 2009, 6:56 AM
I had the oportunity to investagate a buddy of mine's 400A motor *Censored*. I was able to reproduce the voltage regulation circuit and I'm currently converting a 24V 150A fork lift battery charger into a variable regulated power supply so I can run my 1X4 mobile box on my base station. The voltage regulation circuit is simply controlled by a LM317T variable voltage regulator circuit thats driving 8 2N3055 NPN power transistors that are capable of 15A each. Of course there are several other electronic parts like diodes, resistors and capacitors and such but all in all it's pretty basic. My first prototype consisted of the 317 circuit and 4 3055's. With this design I was able to run a T/S Killer Bee with a 24V 50A unregulated power supply at regulated to 15V without any problem. The voltage drop was about a half a volt with no signs of over amping my circuit. If I can talk my buddy into letting me gander inside his motor *Censored* again, I'm going to get the solenoid wiring figured out and try building my own *Censored*.
Did I mention I love electronics ?
Have a good day........
of all the things I've lost, I miss my mind the most
Alien Abductor
Re:
Post by Alien Abductor » Friday, 07 August 2009, 12:42 PM
I wouldnt suggest building one if its your first project, if your experienced with electronics and understand how they work then go for it.
skeeter
Re: Motor Maul
Post by skeeter » Tuesday, 16 March 2010, 16:15 PM
i had all intentions to build one. i looked in one and closed up the case and called worldwide and orderd a 400 amp. a homemade one can be done but in my opinion you are just paying for the reliability and the precision from a professional and it is well worth it my friend.
livin life one-lap-at-a-time.
skeeter in the southeastern buckeye wavin a hand from the driver seat of the mudduck mobile.
executioner
Re: Motor Maul
Post by executioner » Wednesday, 17 March 2010, 14:11 PM
Darkskies wrote:I had the oportunity to investagate a buddy of mine's 400A motor *Censored*. I was able to reproduce the voltage regulation circuit and I'm currently converting a 24V 150A fork lift battery charger into a variable regulated power supply so I can run my 1X4 mobile box on my base station. The voltage regulation circuit is simply controlled by a LM317T variable voltage regulator circuit thats driving 8 2N3055 NPN power transistors that are capable of 15A each. Of course there are several other electronic parts like diodes, resistors and capacitors and such but all in all it's pretty basic. My first prototype consisted of the 317 circuit and 4 3055's. With this design I was able to run a T/S Killer Bee with a 24V 50A unregulated power supply at regulated to 15V without any problem. The voltage drop was about a half a volt with no signs of over amping my circuit. If I can talk my buddy into letting me gander inside his motor *Censored* again, I'm going to get the solenoid wiring figured out and try building my own *Censored*.
Please tell us what electronic compnents you will be using to pass 400A of current.
That could be allot of 2N3055's !(like around 30) :biggrin:
busdriver389
Radio: rci 2950, 93T,99V
Re: Motor Maul
Post by busdriver389 » Saturday, 29 May 2010, 21:41 PM
I have a home built 400a. It was built by a local ham guy. One of these days I'm going to take it apart, so I can copy it.
We're all going to die, but I've got a helmet.
drdx
Re: Motor Maul
Post by drdx » Sunday, 30 May 2010, 7:35 AM
What about a very basic *Censored*, one that just allowed the multiple batteries and that would take the vehicle out of the mix when keyed, and not worrying about volting, just a stock voltage deal with an rf triggered relay. Heck, it could be just electrically triggered, like an hf amp.
Then, build from there, but that would offer the bandaid that a *Censored* offers. Volting will give you a bump, but even if the volting doubled the power, that's not much as far as signal in the big picture.
