Swan 350etc.
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Antenna: Gainmaster homebrew@25'
Radio: CPI CP2000
Swan 350etc.
Post by narfedwards1 »
The Shack
Narf!
XM42-9578
North Shore Lake Ontario
"The Shwaaaa" Unit 421
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Up close a bit more
Narf!
XM42-9578
Re: Swan 350etc.
Back in the day they were known as the "Drifty 350", good radio,, thanks for the pics.
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Drift is easy fix...couple new temp.compensating caps in the right spot and relocate VFO board clean bandswitches good now solid as a rock after warmup.120W on 11M from a pair of 6HF5's and 140-150 minimum on all other bands....awesome transmit audio man..also tweaked AGC for nice easy listenen
[ Post made via Mobile Device ] Image
Narf!
XM42-9578
Re: Swan 350etc.
Yes I did that cap mod on my Siltronix 1011C, takes about 10 minutes of warm up and then it only drifts a few hz, keep it inline with a frequency counter.
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
I also have a 1011C with a 6JS6C in the PA and a 1011D Comanche with the 8950.All kinds of old stuff...457 Navahos,CBS-1000,TRC448,Anytone 5555 in the mobile,Emperor TS-5010 prolly more layin around or lent out hahaha
Narf!
XM42-9578
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Oh yeah...just scrapped a Hallicrafters FPM300...using the VFO cap out of it on the magnetic loop ...works real good...hahaha
Narf!
XM42-9578
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Here's the Golden Eagle Mark III etc....so nice
Narf!
XM42-9578
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Oh yeah...almost forgot...
Narf!
XM42-9578
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Mk.III is rocking 38.5 lets go
Narf!
XM42-9578
Trapper444
Real Name: Len
Antenna: I Max 2000
Radio: Ranger base 2995
Re: Swan 350etc.
Post by Trapper444 »
That Mark 3 looks sweet.
Good stuff
[ Post made via iPad ] Image
JOHN 14:6
NRA LIFE MEMBER
GOA MEMBER
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Uh oh,just spent two weeks restoring this Mk.IV combo....so sweet and works so nice...lotta work ta get her in shape but well worth it...man it sounds good
Narf!
XM42-9578
Bobcat
Handle: Bobcat
Real Name: Bob
Call Sign: AI5RR
Radio: SBE Console V ; Sears Roadtalker 40 SSB
Re: Swan 350etc.
Post by Bobcat »
Narf ... that is some really nice "radio gear" you have right there.
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Got an old PAL VFO converted to LCD readout for the Mk.IV.Just have to clean up the face with a piece of smoked plexi.These are very stable VFO's especially since you remove the bulb when you rework them...less drift shorter warm up.Should look ok when done
Narf!
XM42-9578
Bobcat
Handle: Bobcat
Real Name: Bob
Call Sign: AI5RR
Re: Swan 350etc.
Post by Bobcat »
Ok... here is where I get dumb.... really quick!!!!
If you are going to tie an external VFO into say a desktop CB (for experimental purposes into a dummy load only!!! ;) )
DO you have to account for any kind of offset in the mix inside the radio..... or does it just depend on the radio and where you have to inject it???
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
These cheap Chinese counters allow you to select your I.F....I believe for the Mk.IV I set it up for lower offset freq. 5645...then it adds the vfo freq and away you go... sadly this one is generating noise which disrupts the internal S/S pll etc. causing a pulsing counterlike noise.Have tried different caps on the input for better isolation but still workin to get rid of it.Mite need a small buffer amp in between ....when time permits I will try that
Narf!
XM42-9578
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
Vintage Whiteface on its way
Narf!
XM42-9578
narfedwards1
Handle: the fonz
Real Name: Narf
Call Sign: 421
Radio: CPI CP2000
Re: Swan 350etc.
I believe I am set for retirement... added the D201A fully restored.... so nice the audio on this radio.Stealth freq.counter install is one of a kind easily reversed.I can't speak it so nice
Narf!
XM42-9578
