Adjusting DK
- dgbacb4148
- Real Name: David g.
- Antenna: shakespere Big Stick
- Radio: Uniden Washington
Adjusting DK
What special tool if any, is needed to adjust dead key,@ VR6, 8719 board, on a Uniden Washington ? Bear with me somebody gotta do it and it's me.
David g.
David g.
Re: Adjusting DK
A small slotted screwdriver and a watt meter is all most use. A non conductive plastic screwdriver is best but with a VR a metal one won't be a problem unless you drop it or short something out.
- dgbacb4148
Re: Adjusting DK
Thank, that's the answer I was looking for.543FtWorth wrote:A small slotted screwdriver and a watt meter is all most use. A non conductive plastic screwdriver is best but with a VR a metal one won't be a problem unless you drop it or short something out.
Re: Adjusting DK
There are a lot of places to buy the plastic tools online, to adjust the coils needs a hex key, it's always a good investment to buy a set. If using a small metal screwdriver I would add a piece of shrink tube over the metal shaft and only left the blade/tip exposed.
- dgbacb4148
Re: Adjusting DK
Thanks Greg, that's what I have already come up with, a small screwdriver that I have already put heat/shrink tubing on and heated it, made a perfect tool. Is there enough difference in 3.75 DK and what everyone recommends 2.0 watt ? You have a Washington as well and I looked on the schematic and was tough to see VR6. I'm using a RS Power/SWR Meter and who knows how accurate it is, and I just wondered if I need to try and lower DK at all ? Hope the Jeep survived the mound LOL. 3's to you/yours.MDYoungblood wrote:There are a lot of places to buy the plastic tools online, to adjust the coils needs a hex key, it's always a good investment to buy a set. If using a small metal screwdriver I would add a piece of shrink tube over the metal shaft and only left the blade/tip exposed.
David g.
Re: Adjusting DK
It depends on the amp you plan to use. I have an old HyGain Afterburner inline with the Washington, adjusted at 4w DK it shows 25w out of the amp and 110w peak, this is on AM, on SSB it peaks 120-125w. Dropping it down to 2w will save the life of the tubes, that is where I run the Washington, the receiving end won't see any difference in the slightly lower output. I use dummy loads to make all my adjustments, another good investment when playing with radio equipment.
- silvereagle1
- Handle: Silver Eagle
- Real Name: Mark
- Antenna: Sirio Turbo 5000
- Radio: President Lincoln 2
Re: Adjusting DK
That's a great idea about the shrink tube. I used electrical tape on my small screwdriver when i was adjusting pots. I had plenty of shrink tubes just did not think of using them. Great idea for future reference.MDYoungblood wrote:There are a lot of places to buy the plastic tools online, to adjust the coils needs a hex key, it's always a good investment to buy a set. If using a small metal screwdriver I would add a piece of shrink tube over the metal shaft and only left the blade/tip exposed.
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
567 East Tennessee
