Proposed A99 location
- barefoothank
- Real Name: Henry
- Antenna: lil will,A99
- Radio: trc-485, 959,979
I'm planning to locate my a99 at the back of the house about 25 feet away from the tv antenna. I wasn't able to put a ground rod in that area however I'm considering running ground wire from a99 mast to tv mast and then down to ground rod. I've included a picture and a very basic drawing and would like to know what you think. Perhaps it would be better to go on top of tv but that would put me closer to big oak trees. Thank you
hank
hank
- ogdoa
- Real Name: Rob 151
- Antenna: Maco v5000/102"
- Radio: Cobra 2000/RCI2970
Re: Proposed A99 location
Are you using the tv antenna?
151 FRIED CHICKEN
Branson, MO
Home channel
26.845
151 FRIED CHICKEN
Branson, MO
Home channel
26.845
- barefoothank
- Real Name: Henry
Roger that although I should upgrade to pne of those new fangled ones they make.ogdoa wrote:Are you using the tv antenna?
Maybe I shouldnt worry so much about the nearby tree and just put the a99 there.
Don't bother upgrading the TV antenna, the old analog type work fine on the frequencies, digital uses mainly the VHF/UHF bands, you may want to upgrade the coax for it though, it does degrade with time. Remember this is only receiving.
I would put the CB antenna on the roof as close to where coax enters the house and where you have the radio located. If it means moving the TV antenna do so, shorter run with the coax means more wattage is getting to the antenna.
- Buzzweiser
- Handle: Peacemaker
- Real Name: Dave 656
- Antenna: Performer 5000
- Radio: Custom Built 2970N4
For antenna grounding you want the shortest path to ground. You also do not want sharp bends or angles in your ground wire. Consider the circuit path of your proposed ground wire. Should either of your antennas get a lightning strike the plasma stream could run the entire length of your wire which appears to be on your roof. JMO but that doesn't appear safe to me.
- barefoothank
- Real Name: Henry
Copy that, I didn't realize how lame that idea was, Thank you Sir! Think I will replace mast at existing location and blow off tv ant. for now.Buzzweiser wrote:For antenna grounding you want the shortest path to ground. You also do not want sharp bends or angles in your ground wire. Consider the circuit path of your proposed ground wire. Should either of your antennas get a lightning strike the plasma stream could run the entire length of your wire which appears to be on your roof. JMO but that doesn't appear safe to me.
- Mudpuppy193
- Antenna: Maco V 5/8
- Radio: RCI 2950 DX
Why not just put the A99 above the TV antenna? You may have to do some reinforcing for the additional wind load, but that would allow you to kill two birds with one stone.
Hank, I gotta go with MDY for location, closer the better. My Shakespeare Big stick is about in the same enviornment as your A99, close to back door with the exception I may have another 12' section than you do. I live on about 3 acres with lots of huge old trees close to the house, but really good reception. Good luck.
- barefoothank
- Real Name: Henry
I wasn't sure if that would cause an swr issue but other than that I have no problem putting them together.Mudpuppy193 wrote:Why not just put the A99 above the TV antenna? You may have to do some reinforcing for the additional wind load, but that would allow you to kill two birds with one stone.
I'll plan it out so the tv can be attached at a latter time. Thank you
Dave I'm sold on Greg's idea and will implement it.
Thank you
hank
Have you made any progress with all the rain we've had?
- Lost Ram
- Handle: Lost Ram
- Real Name: Kerry
I would put the A99 on top of the TV deal as mentioned. You might even get a little extra length of pipe on top of it too, strength permitting, maybe some guy wires if you do that and a sensible ground too.
There is nothing wrong with the CB antenna over the TV antenna.
CB: TRC-450, Imax
Thomas Jefferson.
Thomas Jefferson.
- barefoothank
- Real Name: Henry
Not much, I may go for the mast tomorrow and order the Jefa Tech 400 cable but if I'm to be honest it's looking like an ecd of July or August.543FtWorth wrote:Have you made any progress with all the rain we've had?
A snail could do it faster than me.
Thank you for asking though.
- Lost Ram
- Handle: Lost Ram
- Real Name: Kerry
I just got 100" of the Jefa LMR400, I love that stuff.
CB: TRC-450, Imax
Thomas Jefferson.
Thomas Jefferson.
I hear you. I finally got one of my mobile amps back inline last weekend. I pulled it out 4 or 5 months ago to make a quick repair.barefoothank wrote:Not much, I may go for the mast tomorrow and order the Jefa Tech 400 cable but if I'm to be honest it's looking like an ecd of July or August.543FtWorth wrote:Have you made any progress with all the rain we've had?
I use the same coax BTW. The insulation around the center conductor is a little harder to strip than it should be but it seems to be good cable.
- barefoothank
- Real Name: Henry
Did you buy their connectors too?Lost Ram wrote:I just got 100" of the Jefa LMR400, I love that stuff.
I have a spool of their 213 stranded core coax. They are only an hours drive from my house, no I don't use their connector. I use Amphenol PL-259's. If you use a hair dryer and warm up the jacket, it make screwing the connector on easier.
- Lost Ram
- Handle: Lost Ram
- Real Name: Kerry
I do not usually but I have bought theirs and they are just fine. I use the Amphenol brand when I can. I also bought a lot of the better Radio Shack silver type ones before they went under and they work well too.barefoothank wrote:Did you buy their connectors too?Lost Ram wrote:I just got 100" of the Jefa LMR400, I love that stuff.
-- Sat May 16, 2015 7:02 pm --
I will have to try that, I bought some because I have to take my beam down and am going to replace from under the rotating section back with the 400 but going to use the 240 for the rotating section.MDYoungblood wrote:I have a spool of their 213 stranded core coax. They are only an hours drive from my house, no I don't use their connector. I use Amphenol PL-259's. If you use a hair dryer and warm up the jacket, it make screwing the connector on easier.
CB: TRC-450, Imax
Thomas Jefferson.
Thomas Jefferson.
- barefoothank
- Real Name: Henry
Ok she's up and runnin, est. 28' to base, goodbye cruel horizontal dipole whom I don't have the expertise to operate properly! whoot whoot!
Oh 1.5 swr on 1 and 40.
Good deal. There may be some people on 35 now. I'll probably turn the radio on a little later.
- barefoothank
- Real Name: Henry
I actually picked you up on your mobile yesterday, just couldn't make contact.543FtWorth wrote:Good deal. There may be some people on 35 now. I'll probably turn the radio on a little later.
-- Friday, 14 August 2015, 15:24 PM --
Whoops, I came here to ask another question when I spotted this erroneous post, it was 353 I was picking up. sheeshbarefoothank wrote:I actually picked you up on your mobile yesterday, just couldn't make contact.543FtWorth wrote:Good deal. There may be some people on 35 now. I'll probably turn the radio on a little later.
