13.8v DC power supply question
Eskimo_Pie
Handle: SCUBA Diver
Real Name: Greg
Radio: Grant XL/HR2510
#368182
Post by Eskimo_Pie »
Hello CBRT!!
Just a quick question. I have an RCI 2970 DX and need a good p/s. According to RCI/Ranger specs, it requires 18 amps. I am considering an Astron RS-20A, but Astron is only rating it @20amps 50% duty cycle with a 16 amp continuous rating. Am I going regret not getting a higher amp p/s like their 35 amp one? Is there another brand that I should look for? Thanks for any tips!!
9-7-1 Coastal Maine Mobile usually hanging out on 38 LSB
At the home QTH, Uniden Madison/Realistic TRC 457
In the mobile, HR2510/Grant XL
Re: 13.8v DC power supply question
#368184
Look at the PS's on DNJ, they have a 30 and 50 amp, both at a decent price. The Astron PS is an excellent choice too, they have several versions that fit what you need. The switching supply is cheaper than a linear supply and half the weight. I would look at one that is more amerage than needed, if you need 20 amps look at a 30.
Handle: Boogieman
Real Name: Bombero
Antenna: 2ft Wire hanger
Radio: RCI 2950 Mirage
#368186
Post by »
Hey..
Also take a look at the Diamond GZV4000 and GZV6000.
Switching power supplys but work great and not a bad price either.
Bombero
383 Boogieman
Slyguy
Real Name: Sly
Antenna: Yes
Radio: Kenwood, Yaesu, Icom
#368302
Post by Slyguy »
I have the GZV4000. Rock solid. Love that it has high current out on the back and a cig lighter plug and low current spring terminals in the front.
Slyguy
Zero Six Three
Sherman Texas
yota167
Real Name: Yota
Radio: Stryker490HP
#368308
Post by yota167 »
I run a Pyramid Power Supply. There readily available in stores, and I open them up and solder new radio leads , with strain reliefs of course, directly off the circuit board so there is 2 "hardwired" 3prong radio plugs. Saves having to pull them off a lot if your tinkering with seperate radios and frees up the stock wire jacks for other things.
Yota167
Getting back in the game...
TheCBDoctor
Sponsor
Sponsor
Handle: Rick
Real Name: Rick
Antenna: Wilson 2000
Radio: HR 2510
#368373
Post by TheCBDoctor »
Good morning Eskimo_Pie
The rule of thumb is: Whatever the current draw needed you should add 50% to that. Since Astron does not make a 30 amp supply you need to go 35 amp. I love Astron; they are the best made in my humble opinion and worth the money if you use them and plan to have it for 20 years without repair. They are low ripple (Clean) durable, and come with many features or a basic model.
I have a Pyramid but it only lasted 2 years before needing repair, and it wasn't as if I pushed it to the limit. They are inexpensive and will be fine for what you plan on using it for. You will need a 35 amp.
I don't like switching power supplies. Yes, they are light and can provide the current, but the one I have in my shop Sorensen DCS80-13E is good from zero to 80 volts and can supply 13 amps continuously at 80 volts. It has a variable current limiter. The biggest problem is the fan keeps coming ON and it noisy (And I mean NOISY). It interferes with my tests requiring audio.
If you are going to use just that radio, then the 35 amp Pyramid will be fine. If you are going to do tests and switch out radios, then go with the Astron 35 amp. Others swear by their switching power supplies. I have one, it wasn't cheap, and I hate it for no other reason because the fan is loud.
Respectfully as always,
Rick
Eskimo_Pie
Handle: SCUBA Diver
Real Name: Greg
#368742
Thank you for everybody's input. :cheers: I am watching ebay for a decent rs-35 Astron to come along. In my case, I am living in an apartment and cannot raise any sort of antenna, so right now the P/S would be used only occasionally for bench testing and such. Would having adjustable volts & amps be a good thing? Or should I just get a fixed volt/amp P/S?
1206FL
#368749
Post by 1206FL »
Man for what you are wanting a small switching supply would work just fine and not take up very much room and the one I have the fan is whisper quiet. I leave it on at night and it's right next to the bed so I would think I'd notice if it was too loud. The site MD posted is where I got mine, the s-400 , I use an icom 746 as a base with it and have no issues with hash or not enough amps. For the money they are great little supplies. 67 shipped I believe. The Astron supplies are nice but are heavy and take up a bit of room. JMO. Good day.
WINKDOGG420
Mud-Duck Sr.
Mud-Duck Sr.
Handle: 4-2-ZERO NJ not 420
Real Name: Brian Winks
Antenna: Maco V 5/8 , Wilson
Radio: Connex,Cobra,Galaxy
#368802
Post by WINKDOGG420 »
I never heard anyone complain that they wish they bought a smaller power supply :)
