102 Whip
Re: 102 Whip
I run a 102" whip on my pickup, you can look at some of my old posts I'm sure you'll find pics of my install and mount.
- HOUND DOG
- Handle: Hound Dog
- Real Name: Rocky
- Antenna: Shooting Star
- Radio: Many
Re: 102 Whip
I did away with the 102" and spring and bought the 108" whip instead. A lot less flopping around and better swr than the 102. Its mounted on a Tri-Mag with 5" magnets dead center of my Ford F150 extra cab. I also ran a 1-1/4 " copper braid strap from the mount to the trucks frame though it probably wasnt needed. I run this 108 with a 2x8 FB amp and 9914 davis coax cable. SWR is 1.3 (sitting still)even with the amp on:-) A fine tuned BEAST!....
*In a Galaxy far far away*
- Grinder74
- Handle: Grinder
- Real Name: Chris
- Call Sign: KE8EOJ
- Antenna: 102"GP, 2M Yagi
- Radio: Kenwood TR-751a, Yaesu FT8800, President HR2510, Uniden TRC-465, Teaberry "T" 40ch
Re: 102 Whip
I ran one on a Saturn with homemade trunk mount. Worked great but looked like an RC car!
[ Post made via Android ]
KE8EOJ
- 443 Arizona
- Mod Duck
- Handle: Double R
- Real Name: Steve
- Radio: madison on 5/8 wave
Re: 102 Whip
out of aluminum,i made a 4" puck with a 4" backing plate for my SS whip and spring,ball, i think i am at about 109" but still flat swr . i should have made a blueprint cuase not i cant remember .
- AmEagle124
- Real Name: Ralph
Re: 102 Whip
I have a 102 SS whip on my Toyota Tacoma. Had to purchase some brackets for mounting. Bought two of them because I will co-phase them eventually. Had to move the mounting back a couple of inches from the cab, though. Too much SWR. No spring. The only noise I have is from the AC blower motor on high!!!
