2x4 amp in dodge nitro
rosman6119
Real Name: tom
Antenna: PREDATOR 10k SHORT W
Radio: custom built 98vhp
Post by rosman6119 »
Ok I was wondering if anyone would know if I can run a 2-2290s driving 4-2879s xforce amp in a dodge nitro with stock alternator or do I have to change anything it is a 2007and if I need to change is it a big job or simple swap out.
Deleted User 14541
Re: 2x4 amp in dodge nitro
Post by Deleted User 14541 »
Do you know the rating of the alternator? It will probably be fine in the power dept. If you need more juice a high output alternator and heavier charging cable can be bolted right in. Your biggest problem is going to be keeping RF out of the vehicle electronics. Especially running a 2x4 that you can overdrive with a walkie talkie.
