Pills
- Real Name: Eric
Re: Pills
more then likly they are a old version of a motorolla 1446 transistor.. or pill as people like to call them, my guess is that because you said it has the m on it, and it looks and sounds like you are pretty on the money of the power output of a m 1446. and i think but not sure a 1446 can draw around 4 to 6 amps per pill, all depends how hard you drive the amp. that being a 2 x 1446 it should really not pull more then 15 amps. good luck hope that helps you. a old tech could prob look at them and tell u for sure... ny 221 northeast corner.. u can catch me on the bowl ch 6 with the maul dropped down haha
- goldeneagle
- Real Name: 202
- Radio: GALAXY 99V
Re: Pills
HOW MANY WATTS CAN YOU GET OUT OF A 2PILLS 2 2990
- str8stroke
- Real Name: Ric Flair
- Antenna: 1/16 Wave Dipole
- Radio: Gold Cobra 29LTD
Re: Pills
Tricky question! Guess you have some variables..how they are volted & how they are driven? poss swr?? RMS, or swing watts?goldeneagle wrote:HOW MANY WATTS CAN YOU GET OUT OF A 2PILLS 2 2990
- Real Name: Ed Sieb
- Radio: OmegaForce S45 HP
Re: Pills
A pair of 2290's will give you anywhere from 180 to 250 W out depending on drive power and DC voltage. Typically with 13.8VDC and let's say 4W drive, you will get around 200 W out. 14.VDC will give you even more.
Ed - VA3ES
- Fatman0247
- Real Name: DJ K
- Antenna: Coat Hanger
- Radio: Yaesu FT 101EX
Re: Pills
I'll tell ya what, i had a KL400 in my old truck modified for 11m use, it never did me wrong, if anyone is looking to get rid of one, let me know!
"Height is Might"
2WR1247
2WR1247
1247 With the CBRT Wave!
- silvereagle1
- Handle: Silver Eagle
- Real Name: Mark
- Antenna: Sirio Turbo 5000
- Radio: President Lincoln 2
Re: Pills
Does the newer kl 400 amps have the newer green circuit board?? The green boards seem to be better to me. My kl 200 has the new board compared to the old ones. (Ready to use)I believe on the old tan boards you had to remove a chip to use on 11 meters. I want the kl 400 but I want to make sure it has been redesigned like all the others. Wood like to see it in the blue color as well. Does anyone know if they are changing colors on all their amps or just some of them?
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
567 East Tennessee
- BigRed2294
- Handle: Big Red
- Real Name: Alex Faulkner
- Antenna: Wilson Little Wil
- Radio: Cobra 29 LTD Classic
Re: Pills
how do i open my amp if the cooling fins are riveted on and the only other screws are the ones that hold the connections on in the back? do i dare drill the rivets out?
- redlght
- Antenna: astroplane
- Radio: a few diifferent
Re: Pills
2sc2990 or equivalent out of circuit testing of diode bridges
Base to emitter will show a resistance in one direction only.
Base to collector will show a resistance in one direction only.
Emitter to collector should show open both ways.
any other readings it is either open or shorted
(Collector marked with a slanted edge)
- Real Name: Richard McDonnell
- Antenna: Imax 2000
- Radio: President McKinley
Re: Pills
Yeah it's a pill, and a good one. The SD1446 was designed for SSB. Two of them are used in RM's KLV 550 which was a good amp but I overdrove it and it died.
743
743
- silvereagle1
- Real Name: Mark
Re: Pills
Boy has this amp come a long way since 2007.BigBopper wrote:Many questions about pills, they are the transistor in an amp, looks like an aspirin, look at the picture you'll see a white transistor"PILL"(1446)
Tuesday, 24 December 2013, 14:15 PM
2012 model
President Lincoln 2
567 East Tennessee
567 East Tennessee
- Real Name: Sean McCarthy
- Antenna: Sirio Vecotor 4K
- Radio: Icom 746
Re: Pills
Hey fletch57, I would lower your dead key to 2 watts and see if it keys up, and what the key up watts are, the 1446 transistors don't like a lot of dead key wattage as far as I know, may sound better with a lower dead key unless the amp calls for a 4 wat dead key.
- Foliant
- Real Name: Patrick
- Antenna: K40 SF300
Re: Pills
You may lift up Base and Collector to measure a PillThe-kid wrote:hey is there a way to test the pill's in the box with out takeing them out ?
You may lift up Drain and Gate to measure a MOSFET
de 13PR87
- Skipper 169
- Real Name: Mr. Mudd Duck
- Antenna: Antron 99
- Radio: Yaesu 101-E
Re:
No, they are the new junk.Runt wrote:What's this "Mosfet" final I'm hearing about? Is this the new rage??
2WR169 Wisconsin
Some people just need a high five.... In the Face.... With a Chair...
