Golden Eagle 750
- bluemeanie
- Handle: Blue
- Real Name: Mark Schwab
- Antenna: Max 2000 MACO M105
- Radio: LOTS OF TUBES
Golden Eagle 750
I received an E-mail regarding the schematic on a Golden Eagle 750. The schematic i have is for the 1000 which is 2 driving 6 instead of four. Should be similar so I will attach a link for everyone.
https://images.search.yahoo.c ... mp=yhs-002
Re: Golden Eagle 750
Everything inside is the same except the 750 only has 4 main final tubes (1000 has 6), think they should be 6LF6's.
- bluemeanie
- Handle: Blue
the Kenrich amps all use 20lf6. they actually were designed for 27lf6. The heater voltage on the runs 27 to 29 volts. the tubes run really hot. Not a problem anyways because both tubes are cheap a plentiful.
Oops,, typo,, meant 20LF6's.MDYoungblood wrote: ↑January 6th, 2018, 11:49 am Everything inside is the same except the 750 only has 4 main final tubes (1000 has 6), think they should be 6LF6's.
