I have a davemade 5 transistor amp and I wanted to add ssb to it can anyone tell me the best way to do this.
[ Post made via Android ]
Davemade m400
- smoke blower
- Handle: East coast broadcaster
- Real Name: David Sadler
- Radio: Cobra 2000
Re: Davemade m400
You will need to bias the transistors, add a cap to the relay and a switch, that is just to start, I'm pretty sure there is more, I'll let the amp guys tell you what else.
- smoke blower
- Radio: Cobra 2000
Re: Davemade m400
Ok thank you Mdyoungblood
- Crusher
- Handle: Crusher
- Real Name: Rob
- Radio: Cobra 29
Re: Davemade m400
Biasing is a bit more complicated. I don't do the resistor and diode mod as it's not a good way of doing it. The delay is easy.
[ Post made via iPad ]
- smoke blower
- Radio: Cobra 2000
Re: Davemade m400
I figured that is was best to just leave it alone I don't know anything about amps
