amp question - Outcom "the force"
- Handle: Gadget
- Real Name: Will
- Antenna: A99
- Radio: Cobra 29
so, i was reading a manual that says the buttons are Power/ Rec amp / AM/SSB... the buttons on it say Power, Amp, Pad 1.5db, 3db... do the last buttons still have the same function as AM/SSB?
- jessejamesdallas
Re: amp question - Outcom "the force"
No. The button next to the power button marked "REC" is a pre-amp(receive amp) button for bringing in distant stations, the other two are "Power Output" buttons. (Not AM/SSB)
Highest level neither Blue or Yellow is depressed.
Third level -Press Blue only
Second level- Press Yellow only
Lowest level- Press Blue and Yellow
A little searching I found this on CB Tricks, http://www.cbtricks.com/Amp/t ... /index.htm .
- Handle: Gadget
- Real Name: Will
- Antenna: A99
- Radio: Cobra 29
thanks for the info folks. just wasn't sure.
- skywire4
- Real Name: Dale
What is this track from RF in not get finals in a DX 350 TX Star
I'm not sure on what your asking?skywire4 wrote:What is this track from RF in not get finals in a DX 350 TX Star
