CARDINAL 200 ,an old RF tube amp
- 443 Arizona
- Mod Duck
- Handle: Double R
- Real Name: Steve
- Radio: madison on 5/8 wave
it says CARDINAL 200on the front of this shoebox sized amp.
it looks to be at least 40+ years old,
it has 2 tubes , both GE , 6JG6A
two rotary knobs, one labeled L and the other T. along with ON/OFF switch and a BY/OPER switch
looks fine but have not plugged it in yet,(ac powered)
does anyone have knowledge of this "brand",model,
Last edited by 443 Arizona on October 25th, 2010, 10:49 pm, edited 1 time in total.
- Nagant
- Real Name: Paul
- Antenna: M104C, V-Quad
- Radio: To Many To List
Re: CARDINAL 200
New one on me. The L and T are your load and tune controls as it's a tube type amp. I'd check the high voltage capacitors to see if they are leaking or shorted before plugging her in and turning on. There were some Contex and ABC branded amps that fit your description but the Cardinal I've never heard of before.
- Night Crawler
Re: CARDINAL 200
With a pair of 6JG6's it's good for about 50 watts depending on the plate voltage and drive.
- 443 Arizona
- Mod Duck
- Handle: Double R
- Real Name: Steve
Re: CARDINAL 200 ,an old RF tube amp
well its about time i dust this amp off and see if it blows up.
- bluemeanie
- Handle: Blue
- Real Name: Mark Schwab
- Antenna: Max 2000 MACO M105
- Radio: LOTS OF TUBES
Tubes glow, resistors blow, pills are for swallowing.
I guess the smoke hasn't cleared to get back on and tell us if it's working,, when you do some pics would help identify it.
