Got a super clean Elenco Long Range Linear Amp, looks mint....Problem the tubes inside are a maze of small broken pieces
none of which I can get a tube number off of. Does anyone have a schematic for this amp or have a working one that they can give me the tube numbers. Would be greatly appreciated. Tnx...73's
Elenco Long Range Linear Amp HELP!!!
- farkle
- Real Name: Fred
- Handle: Boogieman
- Real Name: Bombero
- Antenna: 2ft Wire hanger
- Radio: RCI 2950 Mirage
Re: Elenco Long Range Linear Amp HELP!!!
Hey Fred,
Could you post a picture of this amp? Also, post a picture of the inside with the top off.
How many pins does the tubes have?
Support our fine sponsors!
383 Boogieman
- Nagant
- Real Name: Paul
- Antenna: M104C, V-Quad
- Radio: To Many To List
I'm assuming that was a low production amp as there isn't much information on it online and I can't say I've ever seen one in real life either. I'd love to see some pics of it as well.
- Night Crawler
I think it used 807's or 1625's not tv sweep tubes how many pins are on the tube sockets also are they octal sockets?
- Nagant
- Real Name: Paul
There's one on eBay right now. It uses four 6GK6's for output, a 6AQ5 for keying, and a 5U4 for a rectifier tube (unless its converted to a rectifier bridge setup then that tube wouldn't be needed). I'm assuming eBay links are probably not allowed but you can find the amp and see the pics by searching Elenco or the amps full name. First one I've seen. Must be early manufactured amp as it has a rectifier tube.
- Toolman1947
- Mud-Duck Jr.
- Real Name: Tom
Do you happen to have a schematic for the Elenco Long Range Amp? Have a broken wire coming off the relay. Don't know where it needs to be connected. Any help would be appreciated. I can send picture if needed.
