DRIVERS 2X 1446 VS 2X2290
Which would you want for a 2pill driver for a 8pill amp
2x1446
58
23%
2x2290
195
77%
Total votes: 253
goofy
Real Name: d sc
Re: DRIVERS 2X 1446 VS 2X2290
#308328
Post by goofy »
the 2879 will go way over its nameplate capacity. It won't last long or sound good, but it can. That's why people can get 600w plus out of 4 transistors
73_
Mud-Duck Jr.
Mud-Duck Jr.
Real Name: Floyd
Antenna: 4 foot Telescoping
Radio: 1w 2ch Walkie Talkie
#308380
Post by 73_ »
goofy wrote:the 2879 will go way over its nameplate capacity. It won't last long or sound good, but it can. That's why people can get 600w plus out of 4 transistors
Yeah, and harmonically rich, too.
You notice they never use a low-pass filter before the meter. If they did I bet it would show about 450w out of the 600w they imagine they're getting on the band where they want it.
Rooster173
#312946
Post by Rooster173 »
You mean people still use 1446 just kidding but def the 2290 is the superior final
Rooster173
#312947
The Bastage wrote:I don't get it... I keep reading and hearing guys claim impossible numbers from the 2879 100w pep transistor. 450W from 2 2879s? How do you get a 100w pep transistor to output 225% of it's designed power output?
I can understand under rating, such as
6w in = 100w pep out
10w in = 165w pep out
But how do you force another 60w ABOVE MAX OUTPUT out of it?
Well one thing to consider is that this power output is rated at a certain voltage probably 13.8 the standard. People getting these numbers are usually running at a higher voltage closer to 17 or 18. Thus earning a higher power output. Also using radios that are peaked. Hope this helps. Rooster
Rooster173
#312948
When you say 600 plus i hope you are talking about rms. As far as peak goes its nothing to push 4x2879 with 2x2290s and see easily over 800 watts PEAK. And in most cases over 1000 if it is a relevant amp. Rooster
73_
Mud-Duck Jr.
Mud-Duck Jr.
Real Name: Floyd
#312973
Post by 73_ »
Yeah, at 18v or 150% rated voltage of 12vdc @ 100w pep you should get about 165w pep, due to both the higher voltage (+50%) & higher efficiency (+10%) at that higher voltage.
4 x 165w pep = 660w pep @ 18vdc, but pep is double RMS so really, a set of 4 2879s @ 18vdc is only an honest 330w AM amp at no forward or reverse swing, but providing 660w pep. More if you don't mind overheating the transistors to get out of band harmonics which can make a watt meter read higher.
Rooster173
#313046
73_ wrote:Yeah, at 18v or 150% rated voltage of 12vdc @ 100w pep you should get about 165w pep, due to both the higher voltage (+50%) & higher efficiency (+10%) at that higher voltage.
665 watts undriven perhaps then throw in a pair of 2290s driving and you have a different story. 2879s are made to drive plain and simple my 16pill base wont do over 900 watts unless driven max i have seen driven power is 3500rms, it does rund on crazy voltage though somewhere around 20v
73_
Mud-Duck Jr.
Mud-Duck Jr.
Real Name: Floyd
#313048
Post by 73_ »
So you're saying you're getting 3500w from 16 100w @ 12vdc transistors. So if you drive them even harder then they will put out even more, and then harder even more until you get 20KW from 16 2879s!!
Where does it end? Can I get 2,000hp from my Toyota Camry if I just put 1800 shot nitrous into it? Yeah, for about 50 feet them BOOM!
I don't consider destruction of a component a valid rating, but if all you care about is 10 seconds in a keydown competition (if you're lucky) then POP, OK, but 220% of rated design isn't something I'm prepared to accept as real for typical daily use. I'll question the meter every time.
Rooster173
#313104
73_ wrote:So you're saying you're getting 3500w from 16 100w @ 12vdc transistors. So if you drive them even harder then they will put out even more, and then harder even more until you get 20KW from 16 2879s!!
Sorry if I confused you let me put it this way. 8 2290s will put out more than 8 2879s simply because the 2290s take less drive to get maximum output. As far as voltage goes i dont really recommend going over 17 volts. But running at seventeen volts can optimize your power output. My sixteen pill is used for constant local talking and i've owned it a little over five years with no trouble driving it with a 1x2290s driving 4x2879 amplifier. As long as you keep your deadkey reasonable problems are avoidable. Many people try to run a high deadkey it simply kills transistors. Usually i don't swing more than 800watts into the sixteen just fyi
Rooster173
#313106
As far as questioning the meter I buy a new meter every single year to ensure i have the tightest meter around. As i buy sell and trade a lot of radio equipment I try and keep it where people get home with equipment and are amazed when it does more at their house than it did mine. Thanks, Rooster
-=PEAKABOO=-
Handle: PEAKABOO
Real Name: Steve
#314089
Post by -=PEAKABOO=- »
a 2879 will dissipate 250 watts. The ratings are to keep it friendly to other frequencies. At the cost of spurious energy you really can increase someones signal on you and jack off your watt meter all at once.
73_
Mud-Duck Jr.
Mud-Duck Jr.
Real Name: Floyd
#314090
Post by 73_ »
Yeah, at least jack off your watt meter. That additional power output is on 6 meters and 3 meters and 1.5 meters and so on.
If it was a 225w transistor they would sell it as such and make more money. The real power of a 2879 maxes out at 65w AM and 135 pep on SSB if you have 16vdc going to it. More than that is distortion, harmonics and fried chicken.
beavis018
#317538
Post by beavis018 »
If you really want to be loud how about 1-2290 driving 2-2879's. X-200 would work nicely just keep the dead key around 250 or less over all and if be careful watch what your doing you could see 2200 to 2500 peak swing if your 8 pill is xforce and you have all the proper power supplies SWR ETC. I admit you would be running your 8 pill hard but you would be loud and it will last if your careful. Maybe even use a single final radio. If your looking for 100% Duty cycle out of your 8 pill 1-2290 will be suffecint.
73's
:r&r:
MuskyHunter
#335081
Post by MuskyHunter »
Holy batman, I can't believe what I'm reading here...... 1- 2879 is all you need to drive an 8 pill with a bone stock or slight tune on a uniden or cobra, anything more just makes your meter needle happy and isn't on freq. 2-2290 is also fine for the 8 pill with a 29 radio or single final. But hey if you just like to repair amps and watch **Censored** meter watts have at it. It just annoys the locals and no one in skip land will see any difference. To many thinkers here reading spec sheets for performance. Thats your first clue that you have no idea what your doing. If its such a great idea or the better way to do it, we should be seeing dual final radios driving at the keydown line, and the last thing they care about is a clean signal yet alone being on freq. If someone gives you flowers for an all 2879 1x2 amp they must be deaf or have one crappy speaker that they are used to. Try a low pass filter then see how many watts you have in the band.
I'd say stop where your at and do a months worth of reading before you buy, or am I too late. I got tired of reading all the ridiculous overdrive posts. Quickest way to wear out or replace transistors early. You'll find yourself getting alot more responses when your signal is cleaner, more legible than the rest.
Sunday, 03 February 2013, 13:55 PM
Wow, dont I feel like a **Censored** posting on an ancient thread......
-=PEAKABOO=-
Handle: PEAKABOO
Real Name: Steve
#341689
73_ wrote:Yeah, at least jack off your watt meter. That additional power output is on 6 meters and 3 meters and 1.5 meters and so on.
My spectrum analyzer tells a different story. Reread what I posted prior to your post.
Ohio_359
#341702
Post by Ohio_359 »
Comes down to it, they don't make the 2879 anymore either.
Sunday, 02 June 2013, 20:15 PM
The 2290, or even the 1446 is higher gain, but that =/= higher output.
Rabbit Ears
Handle: Rabbit Ears
Real Name: Cliff
Call Sign: WW153
Antenna: Hygain Penetrator 500
Radio: RCI 2995DX CF
#348484
Post by Rabbit Ears »
Right now I'm fussing with a TWO pill amp with a pair of SD1446 Transistor finals. Not bad for a KL 300P... re-biased for AB operation.
You are right........ the 2290 is better for durability. A little bit more....
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
Turner Super Side Kick
RM Italy KL300P (A/B modded) in truck :twisted:
BIRD 43P
HY-GAIN SPT-500 antenna
Lost Ram
Handle: Lost Ram
Real Name: Kerry
Antenna: 570' Loop with 600 ohm open feed line
Radio: Yaesu FTDX 101 MP / TRC-450
#362955
Post by Lost Ram »
Wow an old thread but what the heck.
I think some folks have a peak kit for their peak kit!!!!! My HD 6 pill on 18V dropping to 15V on key does an honest 700 watts with about 70 watts drive. I vote for the one 2290 or 2879 to drive the 8 2879's. Sure you could use two of the either but be sure its variable.
To many folks get hung up on the watt meter readings. They need to make a sounding good meter instead of a watt meter!!!! LOL.
CB: TRC-450, Imax
Thomas Jefferson.
