HB-140 Penetrator
Slowclimb
Handle: Slowclimb
Real Name: Roy
Antenna: Monkey mobile Omni directional home
Radio: Colt BlackShadow SSB
HB-140 Penetrator
#233727
Post by Slowclimb »
Has anyone ever used or heard of this unit. Its a two pill unit TRW PT9784 7629 units any comment would be great thanks.
MoJo
Re: HB-140 Penetrator
#238457
Post by MoJo »
were in the same boat....
I have one here that I am wanting to know about...
sparkie277
Real Name: Gary
#387127
Post by sparkie277 »
Yea, me too. I bought one at Hamfest 2017. I hooked antenna to amplifier; hooked amplifier to radfio. both to a 12vdc cigarette plug . When I keyed up, 2 amp fuse blew. I took amp out of loop and radio works. What must I do?
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
#387131
Post by 295 antenna »
sparkie277 first of all a 2 amp fuse is too small use a ten amp. I had the same issue with a modulater (small) amp and a cig. plug
#387134
Hello sparkie277,
Welcome to the forum. What 295 said is true, the amp alone needs a good power source, wire it directly to the battery is best, make sure you install a fuse at the battery location in case the wire shorts going through the firewall. The amp should have a 14A fuse inline, if not install one as well. Any more help just ask.
As a new member could you post an intro in the "Welcome to the Forum" topic, http://www.cbradiotalk.com/viewforum.php?f=89 , so others here can say "Hi", thanks.
Crusher
Handle: Crusher
Real Name: Rob
Radio: Cobra 29
#387141
Post by Crusher »
Those are small transistors. Do not use a high power or dual final radio on it. It will blow. 20A fuse should be more than enough. Those are similar to MRF455's. Do t need much.
[ Post made via iPad ] Image
