Loss of Power
- JetSetter
- Moderator
- Handle: JetSetter/822
- Real Name: Greg
- Antenna: 11m Dipole, PAT-12, Browning BR-28
- Radio: RCI-2995DXCF
Loss of Power
Hello CBRT, I have a strange question. I had tuned my Galaxy DX959. DK was about 2-3 watts with a swing up to 10-12. I've noticed lately that my swing is only about 6 watts. Now, i did switch antennas from a 4 ft Firestick to a Browning BR-28. And also replaced the stock mic with a Superstar DM-1000 Tornado. Still trying to tweak that in. But would any of those cause my radio to lose output power.
"822" Were Alive and Kickin'
From the land of Lincoln
Re: Loss of Power
What type of meter are you using or it this being seen on the radio's meter? A true way to test a radio is by using a 50ohm dummy load, using one takes away any changes like you said, ie; changed the antenna and saw a difference.
- JetSetter
- Moderator
- Real Name: Greg
Re: Loss of Power
Yes, i have been going by the radios meter. I do have a Workman 3P, which i'll hook up in a bit. And i will look in to some dummy loads.
Re: Loss of Power
Search "dummy load" and build one if you don't want to buy. The easiest is a salt water dummy load.
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
Re: Loss of Power
what MDY stated needs to be done and since you changed the antenna I hope you verified your SWR is the same as your old antenna. SWR can be higher and the radio will cut back in power some.
- JetSetter
- Moderator
- Real Name: Greg
Re: Loss of Power
I hooked up my Workman meter, and everything is good now. SWR is down to 1.5 Still think i might look into a dummy load
