Hi folks I am a new member and need help I run a trap line with no cell service in this area I would like to run a CB in my
ATV side by side I do have a older radio General Grant that works really well in my Truck I would like to put this radio in my RZR but it is all Plastic what type of a antenna should I use
Thanks for any help
Doug
Question on Antenna
- motorhome
- Real Name: Doug
Re: Question on Antenna
Hello motorhome,
Welcome to the forum. They are a neat ride those Polaris RZR's. In my opinion mount the radio and get an antenna mount that is a 3/8-24 thread then you can experiment with antennas. Put the mount as high as possible. My choice would be a 102" whip but anything 4ft or longer would work. The metal frame and roll-bar should be adequate for a counterpoise ground plane.
As a new member could you post an intro in the "Welcome to the Forum" topic, http://www.cbradiotalk.com/viewforum.php?f=89 , so others can say "Hi", thanks.
- The DB
- Handle: The DB
- Real Name: Steve
- Antenna: ¼λ Mobile Antenna.
- Radio: Galaxy DX 55HP
If you have a version with three upper crossbars on the cage, I would mount it to the middle of the center cross bar. If you have one of the two upper crossbar versions I would mount it to the middle of the rear cross bar. In either case, make sure their is an electrical connection to the metal of the crossbar.
With a setup like those vehicles, if you have any issues of being bitten by RF when transmitting, or any other interference/problems, or even problems with the vehicle when transmitting on the radio, you should look at adding an RF choke to the feed line near the feedpoint of the antenna. The lack of a flat sheet of metal immediately under the antenna may make such a choke beneficial.
The DB
The DB
- Stoneman
- Handle: Stoneman
- Real Name: Junior
- Antenna: One Shot Dipole
- Radio: Cobra 2000 GTL
The 102" whip, that would be cool..
- JetSetter
- Moderator
- Handle: JetSetter/822
- Real Name: Greg
- Antenna: 11m Dipole, PAT-12, Browning BR-28
- Radio: RCI-2995DXCF
How about a 5ft Firestick No Ground Plane Antenna. They work great on motor homes and rv's.
"822" Were Alive and Kickin'
From the land of Lincoln
- 295 antenna
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
Welcome Motorhome ,
I like the fire stick idea
