Super star 158 edx
- Handle: bandit
- Real Name: Drew
- Antenna: A 99
- Radio: Galaxy 99 v
Super star 158 edx
I have a super star 158 edx and it has a buzzing when volume is turned down I thank it has some thing do with the Frequency counter but not for sure on that radio thank you
[ Post made via Android ]
- jon6667
- Real Name: jon
- Antenna: dipole
- Radio: icom 7300
Re: Super star 158 edx
could be a bad cap on the frequency counter module. or a leaking cap is my best guess
- Handle: bandit
- Real Name: Drew
- Antenna: A 99
that's what was thanking too but was not for sure one that radio it's different then the older galaxy radio thank you
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
you might look at the wire routing to the freq counter. some times you ca reroute the wires from the others and the buzzing will stop. I had one a couple years ago that when you pulled the speaker cover the buzzing would stop and rerouted the wires and it fixed it.
- jessejamesdallas
Yep...I had a Galaxy 939 that had a buzzing sound...called Galaxy, they said to move the ribbon cable that go's to the back lit face plate away from the Mic jack (and wiring) and that should fix the problem..."It did!"sonoma wrote: ↑September 20th, 2017, 1:19 pm you might look at the wire routing to the freq counter. some times you ca reroute the wires from the others and the buzzing will stop. I had one a couple years ago that when you pulled the speaker cover the buzzing would stop and rerouted the wires and it fixed it.
Wires ran next to the speaker or Mic jack can cause buzzing...Just cut the plastic tie-down loose and move the wires away from speaker wires and Mic wires.
- jon6667
- Real Name: jon
- Antenna: dipole
- Radio: icom 7300
i have one. mine dont do that. but i dont use it anymore. ive gone ham.
i also have a stryker 955hp i dont use either. both are mint collectors quality
The manufacturer made this ribbon originally with a ferrite bead on it but toward the last of production they got cheap and stopped installing them. You can install a snap bead, about 5mm on the ribbon and it will cut the buzz out completely, just be careful not to pull on the ribbon, it can be easily broken.jessejamesdallas wrote: ↑September 20th, 2017, 6:37 pmYep...I had a Galaxy 939 that had a buzzing sound...called Galaxy, they said to move the ribbon cable that go's to the back lit face plate away from the Mic jack (and wiring) and that should fix the problem..."It did!"sonoma wrote: ↑September 20th, 2017, 1:19 pm you might look at the wire routing to the freq counter. some times you ca reroute the wires from the others and the buzzing will stop. I had one a couple years ago that when you pulled the speaker cover the buzzing would stop and rerouted the wires and it fixed it.
- jessejamesdallas
Figures...Manufactures will stop at nothing cutting corners to save a nickel...MDYoungblood wrote: ↑October 10th, 2017, 3:10 pmThe manufacturer made this ribbon originally with a ferrite bead on it but toward the last of production they got cheap and stopped installing them. You can install a snap bead, about 5mm on the ribbon and it will cut the buzz out completely, just be careful not to pull on the ribbon, it can be easily broken.jessejamesdallas wrote: ↑September 20th, 2017, 6:37 pmYep...I had a Galaxy 939 that had a buzzing sound...called Galaxy, they said to move the ribbon cable that go's to the back lit face plate away from the Mic jack (and wiring) and that should fix the problem..."It did!"sonoma wrote: ↑September 20th, 2017, 1:19 pm you might look at the wire routing to the freq counter. some times you ca reroute the wires from the others and the buzzing will stop. I had one a couple years ago that when you pulled the speaker cover the buzzing would stop and rerouted the wires and it fixed it.
- ReedHill
- Handle: ReedHill
- Real Name: Reed Hill
What can you do. It's the way things work unfortunately.
