galaxy dx 55 hp off freq.
bluecurt49
Radio: galaxy dx 95t2
Antenna: wilson 5000
Post by bluecurt49 » Sunday, 02 April 2017, 13:15 PM
ive got a dx 55 hp, and the frequency counter on the radio reads,10,655 But it is on the right frequency with an external counter.all the channels are right on with and external counter and other radios but the counter on theradio will not change from 10.695 , no matter what channel your on
Re: galaxy dx 55 hp off freq.
Post by MDYoungblood » Sunday, 02 April 2017, 13:35 PM
The radio's counter is only reading the first crystal so I think the problem is between the counter board and the channel selector board. The first thing would be to check the board connectors to see if they are tight, if that doesn't do it, start looking for a cold solder joint, that radio is known to have quite a few.
Post by MDYoungblood » Sunday, 02 April 2017, 13:47 PM
Hey,
I see you made another post in a different topic area so I moved the original one here and moved the other to our "double post area", no need for two of he same posts.
bluecurt49
Post by bluecurt49 » Sunday, 02 April 2017, 18:26 PM
its a 55v not hp
Post by MDYoungblood » Sunday, 02 April 2017, 18:30 PM
There isn't much of a difference in the boards, they are all RCI's.
Post by sonoma » Sunday, 02 April 2017, 22:20 PM
from memory I think they made 2 or 3 versions of the radio. hml and V which are single final and the HP version that had dual finals. all else is the same inside.
you 1st need to check for bad solder joints causing you the problem you have with the counter not working right.
